I've traced a problem in a more complex circuit down to the 74LS170 registers (Datasheet).
I swear I have tried almost everything with this chip. I have tried 3 different orders of the chip, so I very highly doubt that the chip is faulty.
I made a separate circuit on a different breadboard, and just tried to write to the chip and read the word back. Apparently I am misreading the datasheet, because I cannot even do that.
I have the addresses set to 0,0. I have Read enable at 0V and i have a double-pole toggle connected to the write enable (which I toggle back and fourth when I want to write data... violently, of course, because I am becoming frustrated). I have the D1-D4 pins set to 5V, 0V, 5V, 0V, and the Outputs are all connected to LED's. So, yeah... Am I understanding the function of this chip? Or am I doing something horribly wrong?
Yes, I have double, triple, quadruple checked the pin numbers.
Yes, the LED's are going the right direction.
Yes, it is plugged in.
So confused...![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So confused...
