Help with 5 Pin LCD and Arduino
Hi
I need help with a LCD that I'm trying to connect to my Arduino board.
The problem is, all of the LCDs that I see on the tutorials and on the internet all have 16 pins.
My LCD has only 5 pins.
There are no part or model numbers on it, so I am clueless to what each pin is for.
I bought it from Maplin.
Could anyone tell me what each 5 pins are for?
Or, could anyone even tell me how to connect it to an Arduino board?
It's probably a serial LCD display. Maplin should have data on it on their website.
Just have a look at their website or email them for the pin assignments. They are bound to have it.
In any case, I have a pile of parralel input LCD displays and went looking for some data on them and found the standard 16 x 2 line display connections are ALL THE SAME (with only tiny variations).
Also, it is likely that 1 pin is backlight illumination, 1 is ground, 1 supply and 1 the serial input and 1 is the enable. Ground is easy to spot, it goes to everything, supply is often next to it - that leaves only three pins.
