Hey there, I'm new here. I know this is kinda sudden but I need your help on my project because I have absolutely zero knowledge about electronics. Fortunately, I know how solder things well enough.
Okay, lets get into details now. What I want to build is a simple wireless key-finder. That should consist of two working circuit. The first one must be able to emit a signal for a set of distance. I need it to be compact, like the car key we usually use and it must have a single button to emit its signal. For the next part, the second circuit must be able to produce sound and shine intermittently. It must be able to receive the signal from the receiver and have a stop button. Also, it must be small that someone could use it as a key chain.
To make things clear, let me explain what will happen if my contraption brought to reality. If you ever lost your keys in a messy environment, with the push of a button, you can instantly find it because it produce noise and light( if the place is dark, just in case). Then, you pick your keys and push the stop button to end the noise.
There, I think that I had given enough explanation for my project. If you ever had any idea how to construct such device, do post the link in the comment section below. However, if you are clueless, like me, you can ask your expert friends to look at my project.
All in all, I know that I'm posting my project at the right place and I certainly confident that someone have the skills and creativity to help me. I will really really appreciate any kind of help from all of you.
