Hello there,
I'm new to the forum and pretty new to the world of electronics. I've been reading a book called electronics for dummies (I said I was new!). I'm currently on the section which talks about FM signals and there is a circuit to create FM modulations which uses a Varactor diode.You should be able to see a schematic of the circuit in question here:
The book just gives the circuit as an example FM modulator but doesn't explain how it works beyond the fact that the modulating signal affects the capacitance of the diode which in turn affects the frequency of the FM signal
I get the concept of the modulating input affecting the capacitance but i'd like to understand both how the circuit works 'step by step' as it were and also understand the design of the circuit for example why the resistors and capacitors are used and placed in series or parallel as they are.
My current understanding of how this circuit works is as follows:
R1 and L1 form a Parallel RL circuit (but I can't find any information of what they actually do??)
I believe that the capacitor in series above the oscillator input may be present to block any DC noise that comes from the Input.
I believe that the other two sets of resistors and capacitors may be acting as filters.
I'm happy to go away and read things if anyone can direct me in the right direction to some resources. Ideally ones which avoid all the mathematical formulas and focus on the function of components and the processes going on in the circuit.
Thanks in advance for any help!
[Mod edited to show circuit]
