Hello everyone. I have this question now that i need help with.
I have a GPS with an rs422 output. I want to protect its output from burning if short circuited to ground.
According to the RS422 standard the RS422 lines have a max 150ma short circuit current.
I want to use fuses in serire with the output to prevent damage in case of short circuit.
I found the Littlefuse model MICROSMD010F-2 . I have the datasheet for it but i dont understand its specs. I am posting a picture with the specs.
It says Hold current : 100ma. I supose it means that it will not allow more than that to pass through.
Then it says trip current 250ma. I what does that mean ? maybe that the fuse goes completely open above 250ma ?
Last, it says Current rating max : 10 A. What does that mean ?
THANK YOU SO MUCH !
THANK YOU SO MUCH !
