Hello,
This is my first post to the forum and I'm a new beginner to electronics, so please go easy with me
I'm building a circuit that will monitor a small AC voltage coming out of a ultraviolet lamp ballast and provide a logic signal (>2.5v) to an Arduino digital input.
The ballast produces a small voltage of about 0.3v RMS (the schematic is incorrect). I pass this through a bridge rectifier which gives me a DC voltage. Then, I have a 10uf capacitor and 60k resistor in parallel.
This design has come about through various trials and tests of what will hopefully give me the desired result of a voltage > 2.5v < 5.0v.
With a multimeter placed across the resistor when the ballast is turned on, I see that the voltage increases quickly and then settles at about 3.5v, enough to make the Arduino register a HIGH logic state.
I've attached a schematic of the basic circuit.
Question: Is this the best way to do this or is this a complete fluke/hack?
Thanks for any suggestions/advice.
Much appreciated!
Steve
Much appreciated!
Steve
