Hello
I am building a synthesiser that uses a basic schmitt trigger square wave oscillator
I have found some info that makes sense to me regarding calculating the frequency here:
http://electronics-course.com/schmitt-trigger-oscillator
which states f = 0.8/RC for the 741S14 model.
However im using a Texas CD40106 which has the following datasheet:
chrome-extension://oemmndcbldboiebfnladdacbdfmadadm/http://www.ti.com/lit/ds/symlink/cd40106b-mil.pdf
I have read in a decent book that the oscillation frequency of the CD40106 is approx - 0.75/RC
I have used the same principles to calculate it as shown in the link above however I am unable to obtain anything close to 0.75/RC based on the datasheet values provided.
So... would anyone know how to calculate the oscillation frequency for this IC?
Perhaps I have chosen the wrong values from the datasheet but I have tried a few options
I assumed I would pick temperature at 25C and use the typical values
The datasheet seems to say that output is +10v and 0V if Vdd = 10v and Vcapacitor is between 3.9 and 5.9 volts which I assume means hysteresis should be 2V? however the datasheet states hysteresis at 2.3V! which confuses me...
anyway if anyone is prepared to help Ill explain what ive done further.
Thankyou!
Thankyou!
