It can't be the same if it's a male plug, it can't have pins underneath nor can it have pins on the corners as those pins would prevent it form sliding into the female socket... If it's a male plug the pins and any mounting will be on the tail end, leaving the entire male body part able to slide into the female socket just like the ones in the auction I linked on Ebay...
You have either misidentified it as a male mini USB or your are not describing it properly... Also as I have stated mounting layout varies by manufactures, not having that information hinders identification... An actual picture would certainly help, in both regards...
