So I'm trying to do a very simple project that involves either a linear actuator or servo. All that I need it to do is when i press a toggle switch one way, the actuator goes up, and when i press the toggle switch the other way, the toggle switch goes down. It needs to be under 7 or so inches long. It also doesn't need much thrust, probably only around 10 pounds or so, maybe not even that. I know the obvious solution is just to buy a linear actuator, however I don't have an extra $150 to spend. Someone recommended a power door lock actuator, but I'm not sure if I could connect that to a toggle switch or not. I have a 6 terminal toggle switch and a 12V battery to work with. So what else do i need?
Platforms
Content
