Hello !
I want to drive a DPDT relay (FEME LCA 002 12 57) from my arduino mega board. So far i used a BC337 transistor but after running it for a day or two having the relay continuously engaged, i found the transistor shorted. The relay coil will draw 45-50ma and has a resistance of 265 Ohms. The relay coil does get warm but i am not sure if that is normal or not. I replaced the relay with a new one of the exact same brand and model and got the same outcome (shorted transistor not blown open).
To be honest i dont know why the transistor shorted since it is supposed to be able to handle up to 500ma of load current. I do use a 1n4001 flyback diode to protect the transistor. Could it be that the 1n4001 is not sufficient to protect the transistor ? Should i use an 1n4004 for example ?
Now i am thinking to replace it wit a mosfet. Any suggestion which one to use or how to select one?
P.S.
I think it might be worth mentioning that i bought the transistors from ebay-china but i would like to upgrate to something more durable anyway so the question about mosfet selection still stands.
THANK YOU!
P.S.
THANK YOU!
