Hi! I have been trying to build a liner power supply using LM317 voltage regulator but I am stuck.
Here's my schematic. All the values are also leveled on the schematic. Since, I was going to use this power supply to run a small DC fan I made so, I didn't bother to add extra caps. Just basic stuff.
I am using a center tapped transformer with 12v-0-12v/1A rating. I am using the both 12v taps to get the output of total 24 volts Ac. Instead of using 4 diodes as rectifiers I am using a D2SBA60 rectifier. I am using 4700?F 50v as an input cap and a 22?F as an output cap. I also added couple of diodes so when the fan stops, the collapsing field won't destroy the regulator IC. I soldered all the components according to the schematics on a perfboard. Turned on the power, used a DMM to measure the output voltage and it was showing around 30 volts. So, the first thing I did was check all the connections. It was all fine. I measured the rectified voltage, it was around 22-23 volts. I measured the voltage with 4700?F cap and it showed 30v. How?? (shouldn't the caps be charged up to the input voltage i.e 22-23?) This 30V was appearing directly on the output. The input and output of Lm317 seemed to completely shorted. So I did a continuity test and yes, it was shorted. Then I measured the voltage between output and adjust pin and it was way higher than 1.25 volts so, at this point I figured out the IC was fried. So, I plugged in another one. It was fried too. First I thought the ICs were Chinese knock offs because I had checked my circuit 100 times and it was good. So I went out and bought couple of more ICs from a trusted supplier. I tested them on a breadboard with a 5v DC input on the same circuit as in the schematic expect for the input cap and the rectifier and they were working fine. Then I plugged one in to my power supply circuit and checked the output voltage. It was 30v. Adjusting the pot had no effect what so ever. Whatever voltage I was measuring at the input(30v) , same was appearing at the output as well. And I had fried another IC. So, now I started doubting my circuit and my soldering. I connected the same circuit on the breadboad with my last Lm317 and turned on the switch. Measured the voltage at the output, same 30v. The chip was fried. And this time, I also saw a spark in the pot in one of the leads connected to the adj. pin. But the pot is fine. I checked it afterwards. Now, can someone please tell me
is happening?
