mc
Hi
have a HP1120 which is about 21" size ..(very nice tube..although has
slight burn marks on it)
anyway FAULT ...too much screen backgrond brightness ... almost can see
the retrace lines ..all video signals there ..but on a whiteish
background .. I thought there be just the normal screen pot @ the bottom
of the FBT to adjust it ..but none ..the two pots are only for H & V
focus .. in the end I just put about 3M ohm resistor between the ground
and the HT to the tube grid board(board on back of the tube ..the HT
thick red wire)..that brought it down ..but still have to run it with
brightness adjustment almost to zero and even some of the contrast reduced
Obviously something has failed ..with no circuits hard to tell..has
anyone had similar experince with this model ..it is probably an open
resistor in the screen grid circuit..
help appreciated
help appreciated
