Help : PWM generation
Hi ,
I want to generate voltage control PWM signal(0-5V) duty cycle vary from 10% to 90% and at the same time i want to change frequency with changing voltage whenever is required.
please help me to design that.
Thanking you,
Pratik
Welcome to EP!
This circuit may meet your needs. Duty cycle is voltage-controlled but the frequency is controlled with a variable resistor.
hi,
i am using the circuit in HV application. can i used that circuit?
The IC inverter used is around 5v (6V max) so that's pretty much the limit.
No idea what you mean "use in a hv circuit".
Possible to interface with an opto of some description.
Best show the circuit.
