http://i206.photobucket.com/albums/...or controller/joystickleftpin23connection.png
http://i206.photobucket.com/albums/...or controller/joystickleftpin12connection.png
http://i206.photobucket.com/albums/...k motor controller/joystickinmiddlepin230.png
http://i206.photobucket.com/albums/...k motor controller/joystickinmiddlepin120.png
Hi
I want to control a low voltage 12v dc motor with a potentiometer joystick.
I would like it to be connected in a way that when the joystick is moved left the motor turn one direction and when moved right the motor turns the other direction and when in the middle there is no movement from the motor.
Ive attached pictures of how the potentiometer is working as it seems different from my other potentiometers i have.
When using the diode test function or 2k ohm function on my multimeter it reads zero (or 1 meaning no change from before connected) and when connecting pin 1 and 2 i only get a reading when the joystick is moved to the left and likewise when connected to pin 2 and 3 i only get a reading when the joystick is moved to the right. With my other potentiometers they have no 0 middle position.
So does anyone no a simple way to wire this to get what i want to achieve?
I can be even using something like two of these in conjunction with each other wired to the single potentiometer-
http://www.ebay.co.uk/itm/12-40V-7A-...ht_2197wt_1259
or maybe two of these ones-
http://www.ebay.co.uk/itm/LED-Light-...item43a8d3c093
Thanks in advance, hoping that someone can help
Hi
