OK so I have a project in mind, basically when I'm playing games on my PC my hands tend to get really warm and sweaty so basically I have found two small fans these ones to be specific: http://www.ebay.co.uk/itm/321636289103 which I want to wire to a USB cable and make into little hand coolers. So basically I know that my USB can output 5V and 900mah so I will wire my fans in parallel because if I have my circuit rules correct then the current will be split and voltage will stay the same. Basically I want to add a variable resistor but I have no idea what size could you advise also will I need another resistor in my circuit?
Thanks,
Ben
Thanks,
Ben
