Hi everybody,
I'm working on a synchronous buck converter.
I use an IR2104 to control both Mosfets 1 and 2 (with arduino).
It worked very well by charging a battery OR by feeding a load (Fig1).
Then after, I created another terminal block to separate the battery and the load (Fig2).
I put a Mosfet3 (order directely by arduino) to connect or disconnect the load according to the voltage level of the battery.
And that's where I encountered a problem that I cannot understand at the moment.
As soon as I turn on the converter, the (6) VS, (7) HO and (8) VB terminals of the IR2104 are burned and the Mosfet1 is heating up. View attachment 45777 View attachment 45778
