I am very new to electronics and I am having trouble finding the right LED Driver for a project. I have a standard wall dimmer that I want to control an led light with. The current driver I have does not dim it only outputs the full wattage 3 watts in this case. What would I need to use to make the LED dim relative to the input voltage from my wall dimmer?
Thank you!
- 3W Dimmable LED Under Cabinet Light
- Input Voltage: 12VDC
Thank you!
