Hi!
I have a project with a high voltage side (340VDC) and a low voltage side (5VDC). It's a high powered xenon flash with a low voltage trigger circuit.
I'm trying to use a 5VDC (currently just controlled by a momentary switch, ultimately will be from camera hotshoe adapter) to close the 340VDC circuit thus firing the the flash.
See the attached schematic.
Basically, this is what should happen (in my mind):
0) low voltage side is open circuit.
1) momentary "test" button is pressed, low voltage signal enters pin 1 of MOC3022 Optocoupler and leaves Pin 2.
2) Pins 4 and 6 of optocoupler close, allowing trigger current from high voltage side to gate pin of SCR.
3) SCR gate receives signal from optocoupler, thus SCR closes, allowing high voltage side to dump into trigger coil and fire flash.
My problem is that it simply isn't working. I thought maybe the SCR or the Optocoupler were fried somehow, so I replaced both, to no avail.
I'm sure it's something I'm missing or misunderstanding, but I can't figure out what it is.
Optocoupler is MOC3022. Previously MOC3020.
I've tried two different SCRs:
- NTE 54001
- 2N6403
Any help is much appreciated!
![photoflash circuit.png photoflash circuit.png](https://makerv2.webteractive.co/forums/data/attachments/9/9551-362038c4761fc5bedf5aabf5abed373b.jpg)
- NTE 54001
- 2N6403
