Subject: Re: Help needed with 'back to back' scr's
[email protected]
Date: 9/13/2004 12:44 PM Central Daylight Time
Message-id: <
[email protected]>
WHY do you "have to use dual scr's in this design"?
Use a TRIAC instead... it behaves as back-to-back SCRs, but is much
easier to trigger.
...Jim Thompson
Another homework assignment (sigh).
For a lamp load, a TRIAC is the obvious choice. Back-to-back SCRs are usually
used in switching inductive loads, where the current and voltage are out of
phase, meaning that the TRIAC won't turn off at voltage zero crossing. Since
B2B SCRs have only one thyristor conducting at a time, you can step past this
problem.
But, since "teach" specified B2B SCRs, you might have wanted to try a Google
search on "Back to back SCR" schematic. Page one of search results would have
showed:
http://www.web-ee.com/Electronic-Projects/data/moc3041.pdf
Look at page 4 of this appnote to get an idea of what to do. Note that the
opto specified, the MOC3041, is a "zero-crossing" opto-TRIAC, which means it
won't do for a lamp dimmer. You need phase control, meaning you have to turn
on the SCR in the middle of the AC cycle. We'll leave the voyage of discovery
to determine the right opto-TRIAC for the job to the OP -- he needs some
"ownership" of this design, I suppose. As a hint, I suppose I could say that
almost all of the alphanumeric characters of the IC you want are correct.
(sigh).
As part of your education, also try:
http://www.google.com/help/basics.html
Chris
