Help Needed: Pio CLD-3080 Problem
prc1
I just came across a Pioneer CLD-3080 LD player with some very nice
features, and I purchased it. However, it has a problem and I'm
hoping someone here has experience fixing it.
The unit powers up. The display lights, but both side A and B
indicators are lit. I can insert a disc, but the drive motor never
spins up when Play is pressed. The laser assembly does seek, and the
lens attempts to focus on the disc surface.
Are there some "standard" things to look for when working on this
player?
Regards, PC
Stephen Sank
Most common fault would be cracking of one or more conductors at the top end of the white
ribbon cable that connects the main board to the laser preamp/interconnection board at the back
end of the mechanism. It tends to get creased from flipping disc sides, and eventually causes
conductors to start breaking at the crease.
Assuming that fixes the basic problem, and it probably will, if the unit has been shipped or
otherwise bounced around since last service, it is almost certain to need re-alignment of the
laser's optical diffraction grating. This is the one thing that really takes practice to get
precisely right, and is the biggest factor in making the unit track properly.
Nevertheless, the CLD3080 & the Elite version of same, the CLD95, are, I think, the best
sounding & best looking(video-wise) LD players ever made, and one of the best sounding CD
players ever made. I always keep at least one of them in my personal "system inventory".
Stephen Sank, Owner & Ribbon Mic Restorer
Talking Dog Transducer Company
http://stephensank.com
5517 Carmelita Drive N.E.
Albuquerque, New Mexico [87111]
505-332-0336
Auth. Nakamichi & McIntosh servicer
Payments preferred through Paypal.com
K
Kurtis Bahr
If the ribbon cable looks good then look for the test points and connect a
scope to the "A" and "C" test points. You should see these toggle as the
lens moves up and down. If you don't, and the cable is good, the most
likely candidate to replace is the pickup and now it starts to get
expensive.
Kurtis
505-332-0336
player?
Regards, PC
prc1
Stephen, Kurtis--
Thank you--VERY good info! I'll check these points out and post my
results.
Regards, PC
prc1
Well, the ribbon cable did have the crease problem, so I ordered and
installed a replacement. Still no go. I can dig deeper, but without
schematics I'll be poking around in the dark. Pioneer wants a hefty
amount for their service manuals--I can get loads of docs for any Sony
product for about half of what Pioneer charges.
It was worth a shot--thanks for the info. If you have any other
insights, I'd be grateful... :)
