Hi all, new to here and I need a little help I am looking at some kind of relay or switch that will do the following,
hopefully all the info I provide will be enough to help.
INPUT 240V
OUTPUT 240V
I need to be able to switch the out put of the live to either pole
So for instance if I had 2 outputs and 2 inputs, could I do the following
input 1 permanent live feed to output 1
when I then apply switched live to input 2 it switches off output 1 and allows live to goto output 2, when the live to input 2 ends it switches back to original state?
Does this make sense?
I basically need to control live output between 2 poles but only use 1 live input (hence me mentioning a permenant live)
Or is there a simpler way?
Be gentle I do understand but lack the terminology.
INPUT 240V
OUTPUT 240V
