Help Needed: JVC DR-MH50S DVD VIDEO RECORDER
Ray Birch
Anybody know what might be likely to be wrong with my DVD recorder with HDD.
When it is switched on, the display comes on screen, but just says 'Loading'
all the time. Is it likely to be a fault with the laser unit for the DVD or
something to do with the Hard Drive?
Any Help would be appreciated
RayB
nvic
Two questions about this problem. First, is the HDD spinning up when
turned on (when plugged in on some DVD recorders)? Second, does it say
"loading..." when turned on with no disc inserted? If the HDD isn't
spinning up, that could be the problem as the unit may be waiting for a
reply from the drive and not receiving it. If the problem is only when
a disc is inserted, it may be the laser. Please reply. nvic
Jumpster Jiver
....unless "loading " refers to a disc. It could be a simple loading
problem related to the disc drawer, like a bad belt, slipped gear, or
bad sensor switch.
Ray Birch
Thanks for your replies folks, I'll look into your suggestions
Spanky
there are two jvc modifactions to be made to the digital prossessing pcb
What modifacations?
Anyway, as for the original poster, it's supposed to do that, the firs
time you turn it on. It will take quite a few munites to compleat it'
setup routine. You've probably turned it of, just before it finished
