michael nikolaou
Hi to newsgroup
I want to implement an RS485 interface to an microcontroller with the
purpose of creating a network of 10 controllers
located about 200 mt from a pc . Although everything is clear regarding the
interface what is obscure is the protection
needed. I've seen schemes using a 100 ohm resistor between grounds and a 2
zeners series connected clamping at 13 volts
between each data line and ground . Other suggestions are zenistors and
varistors , other suggest optical isolation . Does anybody have experience
to suggest a simple solution (it is a cost sensitive application) to protect
the devices and data lines from surges ??? . I know you can't protect from
all surges but a usual protection is ok.
