HELP: need to get away from 9v spdt relays!
Hello, I use 6 5pin 9vdc spdt relays to check connectivity for audio chords, using red/green leds, Im desperate to get into a ssr configuration if possible (smaller solid state of any kind for size)
What can replace this simple 5 pin relay? Is there anything simple? Thanks
You can get spdt relays in a TO5 can. If you give your circuit with power supply and load, I am sure someone can recommend a transistor circuit.
