Warning: I'm just trying to get to grips with electronics; and I'm an old dog, so its hard. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(Let me preempt some responses by saying that I am aware that simulators -- and especially the simple, free one I'm using -- are imperfect representations of reality.)
I've modeled the charge control circuit board from a working, 12V SLA(on its last legs) powered portable vacuum cleaner.
You can view the model here.
Here is an annotated close up of the circuit board in question.![circuits.jpg circuits.jpg](https://makerv2.webteractive.co/forums/data/attachments/38/38130-2c3886df5c09046985fde314d9b712c2.jpg)
I have a bunch of what are quite possibly dumb questions about the circuit, and I hope that I can get some (appropriately simple
) explanations to them.
1) The "hottest" (according to the simulation) component on the board is the 22Ω R18 resistor. Why is this so low?
In the model you'll see I replaced this with a 22k value and everything still works (ie.Q4 still goes into saturation), but the resistor consumes 99% less power.
2) I'm puzzled by the use of the SCRs. I know they can be used as "latches" amongst other uses, but that does not appear to be the case here. And I think they can be used to provide low power control of high(er) power circuits, but that also does not seem to be necessary here. For example:
a) I can remove SCR T3 entirely from the simulation (with or without strapping r15/r16 to ground or c3) and the entire circuit still works. Q4 still goes into saturation and the relay still operates in concert with the on/off switch.
b) Again, I can completely remove T1 from the circuit and everything (all 4 combinations of switch position and with the battery fully charged, and depleted) continues to work. As best I can tell, exactly as it does when T1 is in place.
3) I perplexed by the need for T2 (in conjunction with Q1/Q2) to drive the green LED (actually the green half of a 3-lead bi-color LED), but no equivalent SCR for the red LED?
4) I'm confused by the purpose of C3.
C1 appears to suppress surge when the charger is plugged in (simulated with a switch).
C2 may serve a similar purpose for when the main switch is thrown.
but C3 doesn't appear to carry any current or voltage worthy of note; picoAmps and microVolts only, and no spikes at all from what I see.
Thanks for any time you can spend educating this old dog.
Buk
Buk
