Have you Googled diode incremental resistance? Or diode dynamic resistance?
The curve shows you the relationship between two quantities, for a diode. What are those quantities?
How do you calculate resistance from those two quantities?
To calculate the dynamic or incremental resistance at a certain area of the line on the graph, you approximate that part of the line to a straight line, and use the difference in distance on the two axes to calculate the slope of the line at that point. From these two figures, dV and dI, you can calculate the incremental or dynamic resistance. What formula would you use for this?
What happens if you take two different sections of that curve, approximate them to straight lines, and calculate the equivalent resistance for those sections? Do you get the same resistance each time, or different resistances?
Is it meaningful to say that a diode has a certain AC resistance, without giving any other information? What other information do you need to give?
