Hi Everyone,
I'm new to this forum and this is my first post, so apologies in advance if I didn't select the right place for this question.
My question involves the use of a brushless DC motor (my first!) in a hobbiest project. The tight area constraints of this project required a motor with the smallest possible footprint, so one of the these fancy brushless 18v DC Makita drills really seemed to fit the bill. However, after tinkering with brushed motors all my life, I'm struggling a bit trying to figure out how I'm going to adapt this motor to my project.
So far, I opened up the drill, and pushed the battery and trigger switch aside. Then carefully cut the entire plastic handle portion off, leaving the motor mounted within the remaining portion of it's housing, and all electrical connections still intact. Voila! I now have a very compact and powerful cylindrical motor assembly with a geared socket wrench for an axis.
In this project, I need to control motor direction and speed through two SEPARATE external switches placed around 6ft away from the motor. To do this, I purchased a 30A brushless DC motor controller, with the intent of using it's appropriate wire breakouts for said switches. It's a nice controller by the way. Lots of wire breakouts to control a number of motor functions.
The problem I ran into was that in addition to the traditional 3 thick wires used to power a brushless motor, there are an additional seven ~30 awg wires coming off this motor assembly: Yellow, red, blue, and two black and white pairs. All seven wires run directly into the drill's onboard controller. Now, I'm guessing that the two black and white wire pairs are for hall effect sensors, because I can see the circuit board they're soldered to, and it's positioned around the motor shaft. I'm also guessing that the red wire may power this small circuit board, but what are the other two wires for? The fact that one of them is blue -- the same color as one of the three motor power supply lines -- makes me nervous enough to wonder if they are necessary for actual functionality of the motor itself. So my question is, can I cut these smaller wires off from the drill's onboard controller and still use this motor via my own independent, external controller? Or are these smaller wires somehow necessary to a brushless motor's functionality and need to remain intact?
As a side note, in case you're wondering why I don't leave the onboard motor controller intact and just replace the trigger switch with my own switches, there are problems with that approach as well. First, there are (again!) five small 30 awg wires running from the drill's onboard motor controller to the trigger switch and I have no idea what they do. Secondly, the drill's trigger is a COMBO multi-function (motor speed and direction) switch. Maybe that explains all the extra small wires??? In my application, these two functions (speed and direction) need to be controlled by two SEPARATE switches located 6 ft away.
Any input or advice as to whether or not cutting these additional small wires will directly affect the motor's overall functionality would be greatly appreciated.
Best regards,
Ken
Best regards,
Ken
