Hello everyone!
I'm new here but I've been lurking for quite a while reading up on good info. Unfortunately I've been having problem with my latest project and can't seem to figure it out, I'm an amateur btw. So this is my project!
I'm building a kinetic lamp, not only do I want it to move but also be touch activated, hence the whole exterior structure of the lamp will be made of aluminum. (First question here; Will aluminum work for touch switch?) Aluminum I'm using is thin sheet aluminum from Home Depot:
http://www.homedepot.com/p/MD-Build...lain-Aluminum-Sheet-in-Silver-56064/202091748
So I want this lamp to hang from the ceiling, so I bought a socket:
After that I bought a dimmable light bulb, as I would like to be able to adjust the light intensity of this lamp (one is LED other is fluorescent):
To turn it into a touch dimmable lamp I bought this 3 way touch dimmer to instal into the socket (or so I thought):
http://www.ebay.com/itm/1-TOUCH-CON...CIRCUIT-KIT-/380916453019?hash=item58b063ce9b
And to set up the movement inside I bought a 10 rpm 12v motor:
http://www.ebay.com/itm/DC-6V-Volta...429?pt=LH_DefaultDomain_0&hash=item486e785615
The motor I will later fit with some parts extending to the aluminum sheets I want it to move, but as you can see I (foolishly maybe) just went out and bought the essential parts I thought I needed for this, now I'm stuck on even installing the touch dimmer/on/off switch. I looked up this instructable: http://www.instructables.com/id/Simple-conversion-of-metal-lamp-to-use-touch-swi/?ALLSTEPS
But the wiring is different on the simple socket I have, just one hot and neutral cable going into the socket, I have no idea what to do with the black cable from the dimmer.
How do I wire this thing to get it to work? Do I need different components? New socket? Different dimmer? I did this abomination which I'm scared to complete much more connect to the outlet:
So this is what i need help on, your expertise would be greatly appreciated!
How can i wire or set this up so that when you touch the aluminum body, the bulb turns on and the motor starts running, in turn moving the pieces I'll connect to it?
Is it possible to wire it so that everything turns on in one go? Do I need separate power for the motor?
Is it possible to make? Would be perfect if I would turn a small light bulb socket to a touch sensor one ready to connect to a metal surface and the motor also ready to turn on when you touch the lamp as well.
This is an ongoing project and will later be fitted with a bluetooth speaker but thats for later
I wanna get this issue our of the way first.
Thank you so much! greatly appreciate any input on this, I've electrocuted myself plenty already :/
