Help identify mystery component
Robert Latest
Hello,
I'm having to repair something to which I have no schematics. I need
to replace some kind of dual driver (used to drive a relay) in a
package that looks like a 5-pin SOT23 (actually it appears to be a wee
bit fatter than a real SOT23). Inputs are driven with 0-12 V logic (no
resistor in between), output is like an open collector (or drain). The
functionality is that of a dual N-channel MOSFET connected like thus:
Pin 1 Drain 1; Pin 2 missing; Pin 3 Drain 2; Pin 4 Gate2; Pin 5
Sources; Pin 6 Gate 1. The thing is marked "G145" (with the "45"
rotated 90 degrees).
Actually, adding gate resistors and scraping off some solder resist I
could use a Fairchild FDC6303N as an almost drop-in replacement, but
mainly out of curiosity I'm trying to find out what the original part
is.
Summary:
Package: SOT23-5
Functionality: Dual MOSFET with sources tied together or dual NPN with
built-in base resistors.
Hints, anyone?
robert
L
legg
Hello,
is.
Summary:
Package: SOT23-5
ROHM
UM5K1NTR dual mosfet 5R 30V SOT-353
QS5U13TER ditto 70mR 39V TSMT-5
Check with digikey, knockung off a few of the last letters in each
case.
Dual transistors don't seem to be offered in the 5-pin body.
RL
