http://www.falstad.com/circuit/e-ceamp.html
i saw this link..
what should i put to base?? the link i gave has a signal in the base... what should i put?
i only want to amplify my battery's volt....
i did not saw that before when i did this:
THIS:
im using eb1402 and i have 1.5v battery
what i did is put the positive to the base then put the negative side to the ground... the emitter to the ground also.. then i put the collector to my load and the other side of my load to the ground.
i asked this before here and somebody posted that the collector will be the positive side and the emitter will be the negative side.. by i dont know what's wrong.. my load didn't turned on.. im testing it with a simple LEDs.. i tried it without transistor and it worked fine but with transistor nothing is happening just the transistor heating up...
pls help.. thanks..
i saw this link..
THIS:
pls help.. thanks..
