Somebody can help solve my problem?
Sorry if i use not the right terms but as an amateur with very basic knowledge i do my best.
I want to calculate a 10 ㎡ LED wall and how to configure ( powerwise) 4 panels !! make 1 ㎡.
The primary power source ( main?) is 230 Volt 50 Hz to the power adapter output 5V to the LED panel.( every tile has its own poweradapter)
The given Power Consumption Max800W/㎡ Average:400W/㎡
When i calculate the Ampere ( W=VxA ) my result is a very high Amperage 800=5XA, A=800/5=160
So if i use 10M2 LED Tiles ( 40 pieces) the Amperage current will be enormous. What I am doing wrong?
What to do bring this down to normal Ampere ranges or is my calculation not right.
And if not use other equipment for example big UPC in front connected tot the LED input?
Thank you in advance
Rob
Screen Area 10㎡
Brightness ≥1200cd/㎡
Pixel Density 65536dots/m2
Driving Method 1/16 scan constant current
Brightness Control Red,Green and Blue 4096 Grade/Each
Fresh requency ≥1980Hz
Frame Frequency 50Hz
Input Voltage AC220V/50Hz
Earth Leakage Current <3mA
Temperature-operating ﹣35℃~50℃
Humidity-operating 10%~95%
Controlling system Nova(Sending Card,Receiving Cards and Hubs)
Rob
Screen Area 10㎡
