Hello
I have an old Nokia E72 phone with standard 3.5mm headphone/line-out/etc jack and I've like to hook up a spare external speaker I found from an old 220v FM clock-radio which got it's clock messed up so I put it away.
I already detached the speaker from the radio, I thought it would work but I guess it needs external power,
Specs:
F - F
0.5 W 8ohm
2
and it has a yellow and blue wire.
I do have a local special electronics shop not far that has all kinds of DIY stuff that big markets never have, like resistors, so I rather do something DIY with a battery
But I have zero electronics knowledge, I have no idea what's the voltages, ohms, ampers needed, but I do have a small multimeter at home if needed so it should be easier.
I do have 220-240v line at the location, but there's no any PCs so I would ignore the whole USB speaker thing that I just came across, I can also find an old phone charger to convert to a more managable voltage out of that i could crate a DIY setup.
Specs:
F - F
0.5 W 8ohm
2
