Help for a newbie? Dividing DC power
Alright so here's what I've got going on. I have a forklift I work on everyday, it's electric and the battery is 36v. Long before I came along the lights were broken off and I can steal a 36v supply from the old harness. I have rigged up my own little amplifier with speakers along with a cheap set of lights. I have a small voltage step down circuit because both the lights and amplifier draw 12v. So I step down the 36 to 12 for these devices. I want to add a car lighter socket as well. Now on to my question, is there a way to split the 36v into 3 even 12 volt leads? I quickly wired the lighter socket in with this and it's drawing too much much. The lights dim, and there's a terrible noise coming from the speakers
It is not clear at all what you did. Please explain further with a schematic if possible.
Oh, and no, there is no simple way to make a 36V source into 3 12V sources. However, you could draw 12V from one of the 3 12V batteries that make up the 36V power supply.
Bob
Ok so excuse the crude sketch I made but this is how I have it wired now. DSC_0007.JPG
And this is how I would like to have it wired. With each component receiving it's own dedicated 12v supply. I don't want to chain them together as there are times when The lights won't be running or times where nothing will be drawing power from the lighter socket
davenn
OK that looks reasonable
you need to tell us what the current capability of the 36V supply is
and what current is required by the lights and amplifier
Maximum current from a car cig lighter socked is usually around 8 - 10 amps maximum (actual current through it will depend
on what is plugged into it, but must not exceed the 8 - 10 Amps)
you need to be very careful that is all 3 are in use, the 36V line can handle that and not burn out the cabling
Where is the 36V coming from ?
Dave
3 separate DC to DC converters would do it. The is no way to equally split a voltage like you want to unless the loads are always on and all take the same current, in which case they could be wired in series.
Bob
