Platforms
Content
for now it's my only meter yesDoes this mean that this is being your only meter
well for now yes, although i still think it's the IC power that doesn't give power to the transformer to have an output of itshooting down our pending progress on the HT1500 receiver S.M. Pwr Supply ?
yes accidentally connected the red prop of the meter while it was attached to the 10A max slot to the positive node of the battery with the A scale on the meter to test the battery ampere which cause that failureIs there a possibility of having erred and placed an accidental voltage presence, while testing in any of those modes?
how to test those transistorsThe first things that I would check would the overvoltage protection afforded by two sets of series arranged pairs of transistors.
Their connective function is to serve as protective zeners on that circuit path.
They are being the units Q1-Q8 and Q5-Q6 pairs.
only the ground or to remove the whole transistor?To evaluate, lift the emittter which is being grounded . . .loose from its ground on both sets of transistors..
didn't get what do you mean exactlyAND . . . . . . I hope that when you removed the range knob, that you kept track of the arrangement of the sets of spring connectors that complete connection between the PCB's 8 etched out circular ring segments.
Along with the spring loaded detent indexing B-B.
That should have blown the fuse in the worst case. You cannot test a battery that way. In 10 A range the multimeter is essentially a short circuit.yes accidentally connected the red prop of the meter while it was attached to the 10A max slot to the positive node of the battery with the A scale on the meter to test the battery ampere which cause that failure
Theoretically lift the emitter pin only, if possible. But: we're dealing with smd components here, so lifting only one pin is a bit tricky, not impossible.how to test those transistors
Ed expresses his hope that you will be able to reassemble the multi function selector knob such that all the springy contacts are in their correct positions to make the right contacts for each switch position.didn't get what do you mean exactly
i checked the two fuses and they are alrightThat should have blown the fuse in the worst case. You cannot test a battery that way. In 10 A range the multimeter is essentially a short circuit.
so i'll de sloder it complete from the board to check it, but how to check those four knots smd transistor for shot?For a complete check you would have to de-solder these and check them for a permanent short circuit.
i don't see any component on the board for SG1,SG2Check also varistors SG1 and SG2 for a possible short circuit
will get another one tomorrow i guess, although at the moment i'm using old analog meter with buzz option and ohm testingunfortunately you'll need another multimeter for that.
ah it's a fixed springy contacts to the switch , no need to worry about itEd expresses his hope that you will be able to reassemble the multi function selector knob such that all the springy contacts are in their correct positions to make the right contacts for each switch position.
No need to worry if these contacts are fixed to the knob or their positions are clearly identifiable otherwise.
I was referencing the schematic. These components are obviously not populated on the pcb.i don't see any component on the board for SG1,SG2
These transistors are similar to this one. Look up the respective pin function (base, emitter, collector).so i'll de sloder it complete from the board to check it, but how to check those four knots smd transistor for shot?
No. the original battery is enough.if i use 9 v with 3 amp current on the multi-meter as power source would that help me found the faulty component ?
depend on what scale the meter isThe meter indicates OL - overload. Does that happen when you short-ciruit the inputs (volt/ohm vs. common), too?
But without input there should be no overload in any range.depend on what scale the meter is
Did you check the reference voltage
what is U1Check U1
does it matter what scale to be on?to check the reference voltage the multimeter has to be switched on
