Hi guys,
You've been great at helping find some pretty obscure stuff in the past so here's a real puzzler.
I'm a RC hobbiest and I have a radio control transmitter - it's computerised and I know the manufacturer has a hidden service menu on their models for calibrating them.
In newer models this is done by shorting some pins on a memory module port (clock output pulled low).
Mine is an older version and does not have the memory module port - it does have another port for connecting it to a simulator. There are some reports that in the newest versions this simulator port and the memory port have to both be used to get the radio to enter the hidden service mode - so it looks like it could be a candidate.
The pins on the simulator port are:
0 = GROUND
1 = +V batteries (SWITCHED)
2 = PPM Signal OUT
3 = PPM Signal IN
4 = +V (for some transmitters only).
5 = Connecting pin 4 and 5 to each other on some transmitters will stop the HF-transmission and thus the transmitter will not send out any signal through its aerial and just use the simulator cable.
I think pulling pins 2 & 3 low (i.e. short to ground) look like good candidates for triggering the service menu. I understand what a PPM signal is but am not sure if this will do any damage - could it? Also what do you think? Any ideas?
Thanks guys!
0 = GROUND
2 = PPM Signal OUT
3 = PPM Signal IN
Thanks guys!
