Afternoon!
I need to create a metal box with an adjustable temperature range for an experiment one of the researchers at work wants to run. It needs to hit at least 200 degrees. I planned on using strip heaters for the heat, but am having trouble figuring out how to control the temperature. Most of the strip heaters I have found online reach up to 900 degrees. The steel box I'm having our shop build for us can handle that and I'm sure at some point, one of the R&D guys here may want to reach that level some day, so I'd like advice on what to use that can cover a wide range.
Thanks in advance!
Vic
Thanks in advance!
Vic
