Hi
I'm trying to swap out a small 3-way position sliding switch on a PCB with a bigger and more sturdy one.
I am new to electronics and because of this I approached the task in a somewhat logic way: the small 3-way switch on the PCB has 8 legs, hence I would need to swap it out with another 8 legged switch.
First I desoldered/removed the small slide switch and hooked up the PCB again.
My test confirmed that the PCB with no switch attached to it was in "Center" mode
I then wired up the replacement switch and soldered it on to the PCB
Sadly this did not work as I had hoped:
Left position work
Center position work (but as the PCB by default is in "Center" I'm not too sure)
Right position do not work - the PCB is in "Center"![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Pic of small 3-way switch on PCB and removed:
Replacement switch:
http://www.guitarelectronics.com/pr...ft-2-Way-ONON-Guitar-Slider-Switch-Black.html
Soldered on like this (NOT WORKING):
Do anyone know how I should connect the wires to the pins on the new switch to get this working ?
/ Thomas
Left position work
![3waypos-small.jpg](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-knfCb2oB1Y8%2FVWDuspqU8iI%2FAAAAAAAAAYk%2F4Qa5S71XoLc%2Fs595%2F3waypos-small.jpg&hash=78135a3212ef571529629957e37353fc)
Replacement switch:
![3way_slider_black.jpg](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-RL6j0LeCtm4%2FVWDus-n29KI%2FAAAAAAAAAYc%2FzP5_H5di5Jg%2Fs350%2F3way_slider_black.jpg&hash=03acf098d055699264fbeb14217143f0)
![sws3connections.jpg](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-Ax3_dx_Kajw%2FVWDutWxDA_I%2FAAAAAAAAAYo%2FSy18p8iKMIs%2Fs250%2Fsws3connections.jpg&hash=21dda146a1e7ac2ac96889f382bc0d3c)
![switch-not-ok.jpg](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-2iklL3izVmM%2FVWDus-sQG3I%2FAAAAAAAAAYg%2FmhyLw8upxgs%2Fs458%2Fswitch-not-ok.jpg&hash=aa445636bdac745043a057db8493091c)
/ Thomas
