Hi, all...
Im just starting in electronics and I thought being a master electrician would make it easy. Maybe a little? I need help connecting a 555 timer. I have a manual on the 555CN, but it is like 19 pages long! It's more confusing every time I read it.
First, is it possible to daisy chain a 100 timers. The output of the 1st timer would pulse the trigger on the 2nd timer. The second timer's output would then pulse the trigger on the 3rd and so on. This would go on and on until it reached the 100th timer. I'm not sure if the collective resistance through all the timers would add up to a fatal level?
All I want is this: When Pin 2 is triggered with 1 second pulse of 2 volts, Pin 3 will send an output of 3 volts or greater... exactly .01 seconds later. This output must last at least 1.0 seconds.
I think the reset is pretty straight forward.
Any help would be appreciated
