I have just brought some active studio monitors Samson A6 Resolv. They are 120/240VAC, they have a 250V fuse in them the little glass ones 5 x 20m I think, When I change the switch to 240VAC to use them in the UK the fuses blow in the back of the monitors. What fuses do I need?... I also need to know what amps the fuse should be for the wall plug.
It says on the back of them, "when changing voltage, fuse must be changed"
there is also a sticker on them that says, "Samson A6 Resolv 230V"
other information on the back of them is,
120VAC T2AL 60Hz
240VAC T1AL 50Hz
Power rating - 120/240V - 60Hz/50Hz 175W
Please help, thanks
120VAC T2AL 60Hz
240VAC T1AL 50Hz
Please help, thanks
