Help Arduino Program
int pinA = 11;
int pinB = 12;
int val;
void setup()
pinMode(pinA, OUTPUT);
pinMode(pinB, INPUT);
void loop()
int();
void int()
val=digitalRead(pinB); // read data
if(pinB == HIGH)
Serial.println("PINA ON"); //write serially
else if(pinB == LOW)
Serial.println("PinA OFF"); //write serially
the message is keep repeating. how to stop the message in serial monitor even the pin is still in continuous active high or low status. it's just a one time message.
alright in that case you have many many options for this.
you can use your if statements with some small additions
Code:
int pinA = 11;
int pinB = 12;
int val;
int printed;
void setup()
printed = 0;
void loop()
int();
void int()
if([COLOR="Red"]val[/COLOR] == HIGH [COLOR="Blue"]&& printed == 0[/COLOR])
[COLOR="blue"]printed = 1;     //change state case to 1[/COLOR]
else if([COLOR="red"]val[/COLOR] == LOW [COLOR="blue"]&& printed == 1[/COLOR])
[COLOR="blue"]printed = 0;     //change state case to 0[/COLOR]
first off you dont need to create a function for it, but I can understand your desire to do so.
second you weren't using "val" you were reading into it but not using it in the if statement so I fixed that. (red text)
Third... the big one, I added a state case (the variable "printed") to the if statement, so while it is high and the state is 0 it will print serially then change the state to 1 so it cannot meet the requirements of either the if or else, therefor not printing again. (blue text)
alternative ways you can do this are with case statements with a state variable, interrupts (though depending on the switch you may need to add some buffering in there), and any other way people can think of
hi sir/ma'am how to use eeprom i'm littlebit confused.
void setup()
for (int i = 0; i < 512; i++)
EEPROM.write(i, i);
that is the use of (i, i) can i use different characters like b,a?
#include "eeprom.h"
int pinA = 11;
int pinB = 12;
int val;
int printed;
void setup()
printed = 0;
void loop()
CheckPassword();
void CheckPassword()
checkNum=true;
lcd.print("Correct Password");
ChangePass();
int();
else
lcd.print("Incorrect Password");
void int()
if(val == HIGH && printed == 0)
lcd.printn("PINA ON");
else if(val == LOW && printed == 1)
lcd.print("PinA OFF");
void changePass();
(here to put eeprom codes)
