Hello, ian!
You wrote on Tue, 13 Jun 2006 21:15:32 GMT:
if> message ??>> Hi there people,
??>> My Eizo 9060S picture is "waving" upon start, and after 5-10 minutes
??>> monitor works normaly. Can anyone give me advice what could be the
??>> problem?
??>> Thank You in advance!
if> A common cause of faults which go away as the equipment warms up is
if> dried out electrolytics that as a result have high ESR.
Wavy edges of the picture area is typically caused by mains hum on the power
supply rails. As the previous poster suggested, it's probably dried up
electrolytic caps, most likely the main smoothing reservoir electrolytic in
the power supply section. Read the safety advice here
http://www.repairfaq.org/ before attempting a repair, these caps store a
lot of punch, but if it's dried up it will probably drain its charge pretty
quickly.
With best regards, 3T39. E-mail:
[email protected]
