I'm wondering if anyone can shed any light on a problem I've run into and suggest some solutions as my knowledge is very rudimentary at best.
I have a European 16mm projector I just purchased 2nd hand here in Sydney. The guy I bought it from had it plugged into a 240 to 220v transformer and suggested it's safer if I use the projector with this.
We tested it before buying and all looked good. Just now when I've plugged in at home I connected an audio cable out of the projector and into a brand new 4 channel mixing desk and fired it up. Within seconds the channel on the mixer started smoking. I quickly turned it off but it's now fried.
Why would this be the case? What have I done wrong? And I'm unsure about using the projector now.
Upon reflection I did wonder why he was using the transformer in the first place so I then did the same test without using the transformer and tentatively plugged the audio back into a good channel on the mixing desk and alas it all seems to be working fine.
So my questions are how and why did I fry my channel on the mixing desk?
And is it safe to use this Euro projector straight into the socket here in Australia?
Cheers
Cheers
