hi there this is my first attempt at creating a circuit so keep it simple for me please
A quick description
the circuit is used to warn of low coolant on a car
the green led is lit when the ignition is turned on and the red led and buzzer sound when the float closes the switch this all works ok BUT i need to add a delay to reduce a false trigger as i have found the water movement sometime closes the switch for a second and i get a quick buzz and a flash of the led
so what i require is a way to add a delay so if the switch is closed only for a second or so the buzzer and led do not trigger???
the components used are
red LED = 12v 8.5mA
Green LED = 12v 8.5mA
Buzzer = 3 to 24Vdc 5mA
thanks
A quick description
red LED = 12v 8.5mA
thanks
