Greetings from DTLA in SoCal - I just joined this board I hope this is an acceptable place for this post.
Like many of you, I suspect... I retain and collect just about any power supply I find. I get many of them at salvage yards and hang on to the ones from discarded items and I've even found few trips and rheostats dumpster diving.
I toss most of them into a large crate in my closet without much afterthought. I have a large jar of connectots and tips labeled "dongles" - more than half of the ones I find had the cords cut off already.
This keeps me about 80% prepared for whatever strange item I might come across tomorrow that's in need of a power supply. My question.... (and I know it's going to be difficult to answer since there's no standard device, but let's assume we are in the laptop mid-range electronic small power tool range)...
*Drumroll*. What's and ballpark of acceptable variance in voltage for devices under the 30 volt DC range? Or maybe the better question is how far off is too far... for mostr small appliances and power supplies for computers and laptops - I have been comfortable using a supply with a higher amperage because my understanding is that the device will only take what it needs. I know that's in the best case scenario and does not include scenarios we where undesirable amounts of power may go looking for a new place to be or components to let the smoke out of... Generally 2 or 3 amps higher has worked out ok so far... I've used laptop power supplies that were two or three volts higher or lower than the stated requirement for the laptop when when I had no other options. I used it in moderation and kept an eye on the temperature... but I always felt like it was somehow damaging or shortening the life of the device.
Today in the front of me I have an Altec Lansing surround speaker subwoofer only one thing that requiresthat requires 13v ac. 4a. if you can find the power supply online it runs about $80 but it's hard to find and I'm already invested pretty deep at $6 I don't want to go any further hah : ) . I have a few 12 volt AC ps around here somewhere I think they're at 3a. Assumingi I don't blow the thing up with the wrong pinout that seems like a reasonable substitute doesn't it? I'm wondering if this is one of those things that would have more of a long-term effect on the life of the device work there would be short term effects or risks I'm curious to hear what your thoughts and interesting experiences power supply hacking are...
One day I'll tell you all about my unexpected introduction to the bastard leg... but not today.
Thank you!
Hollister
Thank you!
Hollister
