I have mosfets in to220 package for motor controller.
I need to electrically isolate the mosfet tab from the metal enclosure. So far I have just used a silicon pad for this.
I decided to mount them under the pcb and use bolts to clamp the pcb to the aluminum heat sink, so I don't put bolts through the mosfet tab or need a special washer.
Can I use silicon tube/hose instead of the pad? I have some which fits perfectly over mosfets. I like this because it will stay in place, but I'm concerned about the heat transfer characteristics.
Are mica pads really much better than silicon? Is it worth dealing with the thermal adhesive?
