Here's kind of a wierd question. I would like to try to heat wire (any
kind) to ~40 - 50 degrees for a sustained time with batteries. I would
love to get 10+ hours out of C or D batteries. My question is, is
there an easy way to determine how thick the wire should be, and how
many batteries I would need to do this? The temperature does not need
to be exact, just within 10 - 15 degrees.
This isn't a weird question at all. The whole point of resistance
heaters is precisely that.
But you didn't mention what length of wire you wanted, whether it would
be in free-standing air or another medium, whether the air or other
medium was still or moving and at what speed, and whether the wire
would be actually doing any work or heating something which might
change the temperature. Kind of difficult to give you any advice given
those constraints.
Another difficulty you might have is load life for your batteries,
which might be the final determining factor. A couple of D alkaline
batteries can light a 1/4 to 1/2 amp bulb for 8 or 10 hours. That will
limit you to 3/4 to 1-1/2 watts, which isn't much power. However, your
temp requirement might not be that strict if you're talking about 20
degrees C ambient in still air.
What you might want to do is scrounge some 22 to 220 ohm, 10 watt power
wirewound resistors and gently tap off the ceramic overcoating so as
not to break the resistance wire. If you then break the ceramic core,
you can unspool it and have several inches to a foot or so of high
quality resistance wire. Connect alligator clips to your battery
wires, then starting with the 22 ohm wire, clamp the clips to the wire,
let it stabilize, and measure temp. For the 22 ohm resistor, your
minimum length would be around 1/4 of the total length of wire, or
about 6 ohms. More than that will use the battery up too fast. Do the
length calculations for the longer lengths of wire so minimum
resistance doesn't go below 6 ohms or so. Then just find what you're
comfortable with.
As I said, if your project requires that the wire actually heat
something, or if you're working with something besides free still air,
you might have to get more complicated. Feel free to post back with
more info.
Cheers
Chris
