V
Victor Grund
I have a home theater in a room over a 3-car garage in a cape style
home. Being a cape, this means that along the long axis of the room the
ceiling cuts in on the left and right. It's a bit like sitting under
the letter "A" for lack of a better analogy.
Prior owners installed Juno track lighting at the ceiling along the
center of the long axis of the room. There are 6 Juno V603W-WH fixtures
in the track and they are labeled for R/BR/PAR30 type lamps, 75-watt
maximum. I'm currently using Philips Masterline PAR30L 75-watt halogen
bulbs in them and the circuit uses a standard incandescent dimmer
switch. I usually dim these lights quite a bit.
I'm happy with the Philips' lighting quality and ability to dim to low
levels for theater operation. My problem is waste heat! The room gets
very warm in short order when the lights are in operation. This is a
significant problem in spring, summer, and fall. I have air
conditioning but I find it rather stupid to pay to operate the lights,
then pay again to dump all of their waste heat.
I tried switching to dimmable 15-watt R30 CFL bulbs from GE, but they
they won't dim to the levels I normally use (they are too bright at the
lowest stable dimming level).
I also tried reducing the number of fixtures in the track but no smaller
configuration would provide suitable light for the room.
So, I thought I'd inquire with the experts here for some advice. I
enjoy the lighting configuration as it exists today and I would rather
not go to the trouble of replacing the entire system. So, my preference
is address this with replacement bulbs or worst case maybe replacement
fixtures for the existing track. I'm not sure that goal can be
accomplished, but it's worthy to ask the experts here. Any thoughts?
Victor
Victor
