Samuel M. Goldwasser
I have a PCB with a part marked:
H721A
F749AMD
It's an 8 pin SOIC, with power (+5 VDC) at pin 8 and GND at pin 4.
Could be an op-amp or TTL based on expected function.
I'm assuming Harris - the "H" is a bit bolder than the rest.
Only a few years old, not ancient.
Google seems to have no clue except that the H721A has been asked about
on a sci* group in the past, apparently without a solution.
It really shouldn't be anything unusual or custom,
Some of it's pins are connected to the outside world via 100 ohm series
resistors. Part of an interlock on a laser.
Any info appreciated.
Thanks!
sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
H721A
F749AMD
Thanks!
