hi, i've been working on fixing this HK 775 for a while now. i got this unit from someone who had tried to fix it himself but aside from screwing up a few traces on the boards hadn't really dome much but replace a few resistors only to watch them burn up again.
I began by replacing the burnt out resistor (R481) and fixing the traces on the board. i then checked around and replaced a few suspicious transistors (Q409-412). after checking what seemed like every component i powered it up using that lightbulb current limiter trick and the 100W bulb stayed bright so i shut it off and decided to check that the power supply was working right. disconnecting the power section from the rest of the circuit i tested the voltages and it all semmed right.
I then assumed the problem was with the output transistors (Q427-434) so i disconnected them and powered it up and the bulb dimmed after a brief glow. measuring the transistors it seemed most were open (no resistance E-C) so i ordered a new set and waited like 2 months for them and popped them in.
because i felt i had pretty thoroughly checked around for other faults i decided to turn it on and see what i got. i thought that the lightbulb trick would be sufficient to save the transistors should there be something else wrong. when i turned it on the bulb glowed for a second and then dimmed (hooray!). so i checked for dc on the speaker terminals and saw 55V which was descenging and went down to about 35V in about 10 seconds. shortly after that the dc voltage dropped to 0V and the bulb went bright. checking the transistors now in circuit shows they are all shorted E-C.
so, now i'm just wasting money trying to fix this thing but i am determined as i really enjoy a problem and i have to learn somehow. i guess my questions are:
1. any idea whats going on here? why would the voltage on the speaker terminals suddenly drop like that? i had thought that if the output transistors were shorted that i'd see the rail voltage on the speaker.
2. what could i have missed? what should i be looking for now? nothing seems to be heating up, and i've checked all resistors and caps. i haven't checked every transistor out of circuit because i'd rather not just start pulling out components randomly. where should i be looking?
3. I thought wrongly that the lightbulb limiter would save the output transistors but they appear to be dead again. is it a matter of using a lightbulb that allowed too much current? or is there something else i'm missing about how this is supposed to work?
Thanks in advance for your help.
mbot.
mbot.
