I've tried some Ham Radio forums with no luck. I was hoping you all could help me.
I was hoping I could get some advice about wiring a David Clark headset station directly to an ICOM A110 transceiver radio.
Here’s the issue: I work at an airport an we use these radios, which are fixed to our tugs, to contact the control tower to get clearance to tow aircraft on the taxiways. We currently have this David Clark headset station connected to these ICOM radios through a series of adapter cables and plugs. I wasn’t around when they made this setup but it seems like we are always having issues with poor connections and interference. In addition, the outside temps range from 0°F to 120°F throughout the year. The ICOMs are mounted inside a steel electrical enclosure that is supposed to be water tight but still leaks.
I want to propose a plan to my boss to remove the radio equipment from the tugs and make some “Go Boxes” so the radios can be removed from the extreme weather conditions when not in use. At the same time, I would really like to find a way to wire the David Clark headset stations directly to the ICOMs. Basically bypassing the two audio jacks.
Sorry for the long post and lack of information. I’m trying to piece together as much as I can. I was able to access one of the non-functioning radios to see if I could figure out the wiring but am not very experienced with electronics. Also, I can’t find much info online on wiring the David Clark headset stations. I did find a note from whoever installed the radio, that listed which colored wire went to which terminal. I was hoping to get some assistance and advise from you all. Here is what I have so far. The top picture is what I think needs to happen. The photo is from one of the radios we have now. The other diagrams come from the manual. Thanks in advance.
